antidotcb
Error after find dialog
Hi, there
I use AI 8.7.1 to modify my project. When I try to use "Find dialog" with any searchstring, I got an error, and AI closes.
One more thing: the results are displayed before AI is closed.
The second more important thing is that such error appearsto only in case I'm searching thru my project.
(searching empty new projects goes without any errors)
I have sent my project file to you via email to support at advancedinstaller dot com
Re: Error after find dialog
The problem has been reproduced using your project, is now under investigation. A fix will be available ASAP.
antidotcb
Thank you.
As a workaround you can select the tables from the project were you want to make the search, but make sure you exclude "ControlCondition" table.
