pydna
Repackager not catpuring reg key values correctly
Hi
I've noticed that Advanced Installer is adding an additional \ onto the end of some directory paths that are in the registry. This is causing the application I'm repackaging to fail.
For example it is doing the following
HKLM\Software\FOLDERNAME\DIRECTORIES\DirectoryPATH with a value of C:\Program Files\App\AppSubFolder\
Whereas the value should be C:\Program Files\App\AppSubFolder
This is a major headache, I've done the same repackage test with our old copy of Wise Package Studio 5.5 and it works fine also Admin Studio caputures everything correctly.
Regards
Pydna
Re: Repackager not catpuring reg key values correctly
Hi Pydna,
Can you please send us an e-mail to support at advancedinstaller dot com with a download link for the application that you are repackaging, so we can reproduce and debug this on our machines?
Also, can you please specify which version of Advanced Installer are you using?
