davidrichens
updates failed to install
I am getting an error message with the auto updater.
I suspect it is something to do with the registry, I am using it to detect the correct version and install.
After installing the update it will still detect an update is available.
I am extracting files using an SFX archive, so I can only assume that the updater isn't updating the registry to the latest version, and this is the cause of my problem. If this is the case, I will have to create an installer rather than an SFX archive.
The updater will display, download and install the update successfully, but at the end it will display this error message:
(I have also attached my ini files for investigation)
updates_client.txt
(479 Bytes) Downloaded 927 times
update.ini
(319 Bytes) Downloaded 900 times
mihai.petcu
Re: updates failed to install
Can you please use regedit and make sure the registry entry value corresponds( after installation ) with the detection criteria set in the updates configuration project?
AdvInstTester
I have the same issue. I have checked that ComapyName/ProductName folder has been generated but no registry key named "version" is generated on new installation or after the update. I found this issue when i set version string from x.x.x to x.x.x.x means upto 4 digits.
What is solution. Please guide, Its still failed even i have revert back to vesion string upto 3 digits like x.x.x
If you encounter the same problem as above, then most likely the definition of your install condition is wrong.
Note: The version should be created by default on all Advanced Installer projects - this can be seen in the Registry page.
Unless you manually removed it, it should be there.
If you removed it, you can always create a new condition by yourself and add that condition in your Updates Configuration File.
AdvInstTester
Catalin wrote: ↑Tue Jan 09, 2024 3:18 pm If you removed it, you can always create a new condition by yourself and add that condition in your Updates Configuration File.
No, It is not removed by me. It exists in 2 places which is confusing me. At WOW6432Node folder and normal 64-bit path, but version key does not exist in the second case. I have posted my question in detail here. Please check the following link and guide me.
Error code 0xE000000C during update
From what I can see, my colleague Liviu has replied to your other thread.
Please continue the thread with him.
