Kleetus
Games Explorer description
Currently, the Games Explorer description area is far too small and only suitable for a single line or a few words.
Most games have a paragraph or more for the description, so this results in the words being truncated.
It is extremely difficult and very annoying to work with, I basically have to copy to notepad back and forth to make sure the text is structured OK.
Is there a way in future versions you can improve this by increasing the area and providing a scroll?
Thank You.
Re: Games Explorer description
In the current version of Advanced Installer scrolling is possible in the "Description" field, also the text can be divided into multiple paragraphs, just as desired.
Indeed the small size makes it a little bit more difficult to edit larger texts, this is because we considered that this text is not often changed. Usually a description is carefully
written when the game is created changes only if new feature/major improvements are brought to it. I shall add an improvement on our list to make the control resizable in one of the next versions.
Kleetus
Hello Bogdan,
Thank you for your support, I appreciate it.
flogger123
I've been waiting for this feature too. Image
Return to “Feature Requests”
