gsimpson
Font Shortcuts
Greetings,
I seem to have a problem with shortcuts to Fonts and require some assistance. I have included the AIP file, the verbose log and the font that I wanted to install in the zip file below. This is what I have done. I have not tried it on anything else but a Win7 machine. My goal is to create an installer that creates a windows Shortcut in the Fonts folder. I do not wish to copy the file to the Fonts folder. I have configured the Fonts folder to accept Shortcuts.
1. Create an installer that has 1 font file in the APPDIR folder.
2. Create a Shortcut in the WindowsVolume\Fonts folder that is from the one installed font.
3. Run your install.
4. Run the install again for a removal. Be prepared to wait a very long time. Then you will get a Warning 1910.
Any way around this?
On another note, there is a way in the installer to automatically check the "Allow fonts to be installed using a shortcut"?
Greg
setup.zip
(163.72 KiB) Downloaded 327 times
mihai.petcu
Re: Font Shortcuts
Hi Greg,
Please keep in mind this option is only available starting with Windows 7.
I can confirm this behavior on a Windows 7 machine. Please give us some time to investigate and we'll get back to you when we have a conclusive answer.
There is no predefined support for this in Advanced Installer. As an implementation hint, you can export your registry( regedit tool ) before and after manually applying the setting in Control Panel. After doing this you can diff the two exported files and find the registry value you need to set during the installation( from your Advanced Installer project ).
gsimpson
Re: Font Shortcuts
Has there been any investigation regarding the Shortcut in the Fonts folder?
Greg
mihai.petcu
Re: Font Shortcuts
Hi Greg,
It seems Windows Installer does not support fonts installed through shortcuts. The solution is to install the font file.
