udayk
Script running to Remote SQL Server is failed
Hi Mihai,
I have a conflict regarding Script running through through AI-8.8.1 Remotely.
Establishment of SQL Server connection (Client to SQL Server 2008 through remotely) is successfully through parameter handling using dialog.
I performed this in SQL Scripts the passing parameters are...
Connection Type : Microsoft SQL Server /MSDE
Connection Mode: ODBC Driver
ODBC Driver : SQL Server
Server : [DBNAME_PROP]
Port : [PORT_PROP]
Username : [USERNAME_PROP]
Password : [PASSWORD_PROP]
I passed arguments like this and enter data in the SQLConnectionDlg only Server([SERVER_PROP]), Username([USERNAME_PROP]), Password([PASSWORD_PROP])
after entering data the CONNECTION was established successfully...
But When script running is starts, it shows an exception, i will attached it.
It throws Username is invalid...
How the Connection is established?????
Can your clarify my doubt
Thanks in Advance,
Udayk.
If i pass parameter like this connection establishment and script running is successful.
If i pass parameter like this connection establishment is successful but unable to script run what is issue?<br />What is the difference between these two process?<br />If i wrong for parameter passing, the connection was not established. what is the issue. please go through that.
This is Script runnin error,what i faced
mihai.petcu
Re: Script running to Remote SQL Server is failed
Hi Udayk,
It seems the connection was not established successfully.
The correct approach includes the following steps:
1 - make sure the connection string is correct( including credentials ) by using another specialized tool like Microsoft SQL Server Management Studio
2 - use this article to test the connection string with Advanced Installer
udayk
Thank you Mihai,
I resolve this issue
Thank you,
Udayk.
navyahbolli
I am trying to establish connection to oracle database to remote server, when i am trying to connect to local oracle database , my configuration is working fine but when i am trying to connect to remote server where my oracle is installed, it throwing username/password not valid, please let me know where i went wrong
I'm not sure why you are encountering this behaviour. Can you please make sure that the Oracle Client is installed on your target machine from which you are trying to access the remote server and try again? For example, you can install Oracle Client on your installation machine and, then try to use the Oracle Client driver (e.g. Oracle in OraClient11g_home1). In order to check the existing Oracle drivers installed on your target installation machine you can run the following commands:
%systemdrive%/Windows/SysWoW64/odbcad32.exe
and
%systemdrive%/Windows/System32/odbcad32.exe
I've attached a sample, created with version 11.4.1 of AI, containing a custom SQL connection added in "SQL Databases" page which uses the following connection string:
Driver={Oracle in OraClient11g_home1};Uid=[USERNAME_PROP];Pwd=[PASSWORD_PROP];Dbq=[SERVER_PROP];
sample.aip
(17.15 KiB) Downloaded 372 times
The sample was successfully tested against an Oracle 11g server and client installation.
Let us know if this helped.
navyahbolli
But this approach didnt work for me to connect to Remote Database.
Can you please manually test the ODBC connection between your Oracle Client and your Oracle server and make sure is working fine outside the installation package?
Also, you can take a look on the "ORA-12560: TNS:protocol adaptor error" thread which could be useful for you.
