kkrzyzak
Error while instaling app in shared folder.
After click install files are copyed to shared folder (maping as K:). It crash with error like in attach.
Reg.,
Karol.
MSI4302c.LOG
(79.56 KiB) Downloaded 432 times
mihai.petcu
Re: Error while instaling app in shared folder.
Hi Karol,
Can you please make sure the installing user has write privileges to the mapped drive? Just try to manually copy any files into the same location.
kkrzyzak
Yes, i have write privileges.
Another problem that i have with AI is when i turn off inherited priviliges to the folder that i wanna install sth. I have the same error as above.
As domain admin i can do everything in that folder (CRUD).
It look's like AI doesn't metter who run it.
Any sugestion?
Reg.,
Karol.
mihai.petcu
Hi Karol,
Can you please send us the .AIP ( project file ) to support at advancedinstaller dot com so we can investigate it?
Also, please make sure you have full access for everyone privileges set for that mapped drive.
