bullyellis
Installer can't seem to find picture but displays in preview
I recently moved my advanced installer project over to a new machine. I moved all of the files and re-referenced them to the correct location on the new machine. Everything went over fine, except for a single image file, so I am wondering if it has something to do with my config.
First off, everything is showing up fine in Themes -> "Preview".
Second off, the image is appearing fine in Themes -> "Images".
I can create the installer fine, but when I run it, that specified background image is not there, and I have a very vanilla grey background.
I am not sure how to proceed. Are there any settings I should check ?
Re: Installer can't seem to find picture but displays in pre
If the installer builds correctly it means all the resources are in their correct locations. You need to make sure now that the graphics where not by mistake replace with other ones, with the same names. Also, are you launching the MSI or EXE file created by Advanced Installer? Please note that for package using Enhanced UI the EXE package is mandatory for launching the install.
bullyellis
"You need to make sure now that the graphics where not by mistake replace with other ones, with the same names."
I am unsure on how to do this? The file in question has a distinctive name. I have attached some screenshots which illustrate the error.
1. Is Themes -> Preview
2. Is Themes -> Images
3. Is the actual installer screen.
Yes, it is a .exe and not a .msi.
Please advise.
Advanced Installer Error.png (442.15 KiB) Viewed 5652 times
mihai.petcu
If you're launching the .EXE as my colleague mentioned and all dependencies are in place everything should work fine.
It is very strange that only one image is behaving this way. You can try to change its name, change its location( string wise shorter path ), save and rebuild the package, anything that would reload it.
If indeed the behavior persists, you can try to isolate the issue on a separate project. Additionally you can send us a copy to support at advancedinstaller dot com so we can help you investigate the issue.
thill
In 9.6.1 our custom DialogBitmap and BannerBitmap are not displayed in the AI Dialogs section. The AI defaults are being used. But, so far it builds correctly with our graphic files.
This was working well in all places, and our files have not been touched. So I can only assume something changed in AI.
Please keep in mind this is the normal behavior for version 9.6.1 of Advanced Installer.
