The project file seems to be correctly configured. Is suspected the advertise option because this is the normal behavior. When Office was loading, it was trying to use a feature not installed, but available on the machine, i.e. advertised. So the OS automatically re-launched the package and installed it.
Since you have advertising disabled something else must be the problem. Have you tested the add-in on multiple clean machines? I ask this because the behavior reported is quite strange. A package even if its launched the second time, it should enter maintenance mode and never appears duplicated in Control Panel.
If the problem persists on multiple machine can you please send us a
verbose log to
support at advancedinstaller dot com so we can investigate further more, or attach it on the forums?
