we are experiancing a problem which is preventing us from re-running the installation EXE file, which we create with AI 8.8.2, from a different directory to the one used to run it the first time. Here is the scenario:
1. We run c:\Temp\MyApp-Install-1.0.0.exe for the first time on the machine and install one feature.
2. We MOVE the exe file to say c:\downloads\MyApp-Install-1.0.0.exe and re-run it (because we want to install another feature this time). We get an error saying that c:\Temp\MyApp-Install-1.0.0.exe cannot be found. (Note: the error is about the previous location of the file).
After some investigation we found that the package creates a registry key HKLM\SOFTWARE\Wow6432Node\Caphyon\Advanced Installer\LZMA\<PROD KEY>\1.0.0\AI_ExePath. If we (manually) remove this key, all works well.
I read some of the posts that come up when you search using "lzma" and "ai_exepath" and I understand that the key is created if we choose to bundle all install files in one exe install file. BTW, we do not select the "Archive installation files using LZAM ..." option on the Media tab.
So my quetion is: how can we enable users to re-run the install file from a different location?
Our users are downloading the install file, installing, and very likely disposing of the install file after installing. If they wish to add a feature, they simply download the install file again and repeat the process (however, the download may end up in a different location).
Thank you
Emil
