RedDrago
Adding and Managing SQL Script files
in my Project I have a large ammount of SQL scripts. It was not so nice to attach them one by one to the project.
That really took a while but i was able to do it in a more or less speedy way.
But now I got a new Computer, and not all pathes are the same as on my old machine, including the source folder of the SQL scripts.
I have to select every single script and I have do a thousand clicks to change the source path.
Unfortunately, I can't use the Table Editor to do so. Once I try to open the table "AI_SQLScript" I get the message that a path has not been found and the table is left empty.
Could you implement a more intuitive way to add scripts to a connection (more than just one at a time) and to alter the source of the script file without thousand clicks with the mouse?
Tobias
Cosmin
Re: Adding and Managing SQL Script files
Adding multiple SQL scripts at once is already on our TODO list and it will be available in a future version. I increased its priority and hopefully it will be implemented soon.
Cosmin
Return to “Feature Requests”
