Zarbon001
Move Folders on the Target Computer Before Install
I need to have my installer copy all of the files and folders in my installers target directory on the target computer before the instillation of my app.
mihai.petcu
Re: Move Folders on the Target Computer Before Install
I'm afraid I don't understand your project requirement. When running an application's installation package, its purpose is to copy the application's resources on the target machine.
Zarbon001
Our situation is that we have our applications information out on many of our client's PC already my manually putting it out there before using Advanced Installer. So before we can go and update the files we need to back up their files so if there is an issue with the new version and their system we can go and replace the old files to keep the product working properly.
Zarbon001
I have a more specific question is there a way to set the location in the back up custom action so that I could reference that location in a batch file and use the batch file to move the files.
mihai.petcu
If you need to perform a backup, here's an article you can follow and adapt to fit your needs.
Zarbon001
The issue I am having is I am trying to specify the location of the temp directory that the backup script will copy to because I need to reference that location in a batch file and will this command copy all of the files in my app directory? [APPDIR]*.*
mihai.petcu
I'm not sure I completely understand what you are trying to accomplish. Can you please give us more details and exemplify?
Zarbon001
I have built an installer for a program that our company has manually installed on many of our customers systems. I am making an updater for that program that will put all of the files from the version in a backup location. To do this I want to run the backup custom action and specify the temp path that it is sending the files on the target computer to and then reference that temp path in a batch file which I w use to move the temp directory to a permanent backup location.
mihai.petcu
tfolder - the property set by the Backup script which designates the temporary directory where the backup files/folders reside. This is the value you will need to set in your .BAT file.
Zarbon001
I tried to do that, but it still didn't work is this what you meant
@echo off
set TIMESTAMP=%DATE:~10,4%-%DATE:~4,2%-%DATE:~7,2%--%TIME:~0,2%-%TIME:~3,2%-%TIME:~6,2%
@echo TIMESTAMP=%TIMESTAMP%
md C:\backup\%TIMESTAMP%
xcopy /e "%tfolder%" "C:\backup\%TIMESTAMP%"
This is what my custom action looks like
example .png (124.82 KiB) Viewed 17576 times
mihai.petcu
If you need to reference that installer property within the .BAT you cannot add it as an environment variable. Even if you created it correctly as part of the installation, environment variables cannot be used by the same process they get created by.
Here's what you can try:
- in the attached custom action from the screen shot set the "Command" field to something like:
"&Backup.bat" [tfolder]
- then in the .BAT file you can reference it like this since it's the first parameter:
%1
For more information you can look how to pass command line parameters to a .BAT file on the Internet. Here's a good place to start.
