kojakfull
"Invalid or missing updates configuration file" updater err
I always get this error when I click updater please see attached image.
2-24-2012 9-28-47 AM.png (22.43 KiB) Viewed 9217 times
Here's my .ini code:
;aiu;
[General]
URL=http://www.xxxx.com/dl/XXX SETUP.exe
AppDir=C:\Program Files (x86)\My Software\
CheckFrequency=2
CompanyName=Blog Commenting Ninja
DownloadsFolder=C:\Users\kojakfull\AppData\Roaming\My Software\My Software\updates\
ApplicationName=My Software
ID={C50D1AC7-B45C-4566-80FC-752543D36A73}
ApplicationVersion=1.0.0
Please help.
mihai.petcu
Re: "Invalid or missing updates configuration file" updater
Does the "Updates URL" field from the Updater page point to your updates configurations file on the server?
kojakfull
Yes it does point to http://www.xxxx.com/dl/XXX SETUP.exe it should be the exe file right?
Let me know.
mihai.petcu
No, the updates configuration file is not the .EXE. The updates configuration file is the .INI you posted initially.
Best,
kojakfull
So I need to change my ini file to something like this:
;aiu;
[General]
URL=http://www.xxxx.com/dl/config.ini
CheckFrequency=2
Can you show me some real example on how the update connect to my server?
The full example is our tutorial for using the updater.
Regarding the error from the first screen-shot you've posted, this appears if the INI file was edited after what Advanced Installer generated it. This file must be saved in ANSI format, and the first characters must be ";aiu;". To check this I recommend a HEX viewer or sending us the original file that you have on your server, by e-mail.
Hasham
Re: "Invalid or missing updates configuration file" updater err
I have fixed the problem, the problem seems to be the "dropbox file url" was in the view mode, usually when we try to share the file it ends with dl=0, it should be dl=1, i tried it and it worked for me!
Hello Hasham and welcome to our forums,
Indeed, you need to provide the direct download link for the updater file. For Dropbox it should end with ?dl=1
Please let us know if you have any other questions and we will gladly assist.
