rn-pro
Necessity to change instances product code by major upgrade.
I have a question regarding the necessity to change the product code of the instances in the case of a major upgrade package.
As I see right now, when the product-version is changed, your application will ask if this change is going to be a “major upgrade” or a just a patch.
If we choose “major upgrade” the product code of the base installation will be automatically changed. However, the product-codes of all defined instances won’t be touched, even if for them, the current package would be actually a major upgrade too.
Is this correct? Can Windows-Installer in this case handle the major-upgrade using the same product-codes just because they are only transforms of the base installation or should we actually take care and change ourselves the product codes of all defined instances?
Thank you very much!
rn-pro
mihai.petcu
Re: Necessity to change instances product code by major upgr
Hi Razvan,
When selecting major upgrade after changing the version in a package with multiple instances, each instance will not have its product code changed.
This means each instance will have a minor upgrade applied in the new version:
http://msdn.microsoft.com/en-us/library ... 85%29.aspx
rn-pro
Hi Mihai,
I see that this is what's going on.
mihai.petcu wrote: When selecting major upgrade after changing the version in a package with multiple instances, each instance will not have its product code changed.
But is it enough to apply a "minor upgrade" to the instances of a product which just got a major upgrade? What happens if this upgrade contains changes which are not possible in a minor upgrade?
rn-pro
mihai.petcu
Hi Razvan,
A minor upgrade is enough because it covers many upgrade cases.
With a major upgrade the default instance can be installed during the first upgrade prompt in the upgrade installer. This way the old instances are removed and the new version gets installed. However, you will have to upgrade the rest of instances by running the upgrade installer once more.
