nigor
Installation path changes when you go back and forth
Using Azure theme, Advances Installer 8.9.
To reproduce:
Choose "Everybody" in installation type dialog.
Navigate to "Choose A File Location Dialog", then go back to "Choose Installation Type Dialog", then navigate to "Choose A File Location" dialog again.
The installation path now changes to C:\Users\xxx\AppData\Local\Programs\... instead of C:\Program Files\...
Correct path:
Good path
Good path
Incorrect path:
Bad path
Bad path
mihai.petcu
Re: Installation path changes when you go back and forth
Hi Igor,
The "Incorrect path" screenshot should be set when selecting "Only for me" in the InstallTypeDlg.
Unfortunately, I cannot replicate this here. Does the behavior manifest on a fresh project? If so, please send us that .AIP so we can investigate the reason.
If the behavior doesn't manifest on a fresh project just send us the one it does on.
