nedumaran
UI Custom Actions
I'm trying to add a CustomAction to collect installation data in my Office Add-Ins installer. The installer works fine on its own.
Problem is, I'm not able to add the predefined UI Custom Action "Send install information to your web server" (or for that matter, any UI Custom Action) to InstallUISequence.
The 'Limit to basic user interface' is unchecked in Install Parameters
The UI Level is 'Full UI' in Bootstrapper UI setting
How else can I add this custom action?
Thanks.
~ MUTHU
mihai.petcu
Re: UI Custom Actions
Hello Muthu,
As mentioned in our "collect installation data and send it to my web server" user guide article, that custom action should be added in the "UI Custom Action" list.
This custom action cannot be manually scheduled in the UI or Execute sequence.
nedumaran
Hello Mihai,
Thanks for your reply. I could not find the "UI Custom Action" list as documented. Perhaps that should have been my question. I've attached a screen shot. Hope it gets through.
~ MUTHU
mihai.petcu
Hi Muthu,
The UI Custom Actions are available starting with the Enterprise project type and license edition.
