mwa
How to enable/disable NEXT button on textbox having text?
I have a dialog with one textbox that the user must enter some specified text to continue the installation.
I want the NEXT button of the dialog to be disabled at first and then enabled when the text box is set to some specified text.
How do I achieve that?
I'm confused about the eventing system in Advanced Installer. The help file is not very verbose about this, it merely state the obvious.
mihai.petcu
Re: How to enable/disable NEXT button on textbox having text
You can have a couple of control conditions set on the "Next" button as follows:
Where EDIT_1_PROP_1 is the public "Property Name" associated with the edit box control.
