anupmistry
Custom Location + Installation Folder 'Program Files'
My app is a 32-bit Office-Addin. By default the plugin got AppFolder set to >> [AppDataFolder][Manufacturer]\[ProductName].
Two part question:
#1 ... if we change it to Program Files. I see two Program Files Listed. In the Folder Property Selection Dialog. What is the difference between the two?
Like .... if my app is installed on a 64-bit PC at runtime assuming the Program Files will become Program Files (x86) and Program Files 64 will stay as Program Files.
#2 .. Was able to edit the AppFolder to [WindowsVolume]\MyAppName\. So its almost like hardcoding to a custom path so I do not have to worry about 32 or 64 bit. Though the AI has the FolderDlg where user can change it. Question becomes how does one bypass that FolderDlg so that after the Accept Agreement it skips straight to the VerifyDialog or just starts the install process ?
mihai.petcu
Re: Custom Location + Installation Folder 'Program Files'
Those folders are described in the "Paths of the folders in the "Files and Folders" Page" article.
You may also find the "How do I install files in a custom folder?" article helpful.
You shouldn't worry about this if you use the folder paths described above. Those are resolved automatically depending on the target machine OS.
To skip a dialog you can condition it using "Show only if" from its context menu (right click).
Maybe the How do I install resources based on the Operating System version? article can help with the conditions.
anupmistry
Thanks. That helped!
