My problem is using the Search Folder function. I use the wizard, "Search for a folder" and try to have the installer search for a folder on my computer named "Adobe" on all fixed drives, with a 10-deep directory search. I test it, and nothing comes up (yes, I do have a folder named Adobe in C:\Program Files (x86)\Adobe). The result was nothing. I tried the same step, but this time I made it search for a folder named "testmovs" (which I have in C:\testmovs). This time, it was successful. I did other tests, and found out that searching on all drives for a specific folder only works for folders that is not in anything else except the drive. This doesn't happen with files though, only folders.
Is it not as simple as it seems?
