ayman
Uninstaller hangs/rollsback on Vista
I have an issue with a specific windows vista machine where [most of the time] the uninstaller will hang or will suddenly rolls back. sometimes it will display visual c++ runtime error message [attached] (but not all of the time)
checking the log, the uninstaller hangs/rollback after this line
MSI (s) (B4:D4) [09:57:19:305]: Invoking remote custom action. DLL: C:\Windows\Installer\MSIDDCF.tmp, Entrypoint: OnAiRemoveFilesUndoable
comparing with a successful un-installation, everything is identical before this line, when it hangs, this is the last shown line in the log.
the rollback (if any) will start after this line (that comes just after the previous line)
Action ended  InstallExecute. Return value 3.
The issue does not happen with other Vista machines.
Thanks for any help
mihai.petcu
Re: Uninstaller hangs/rollsback on Vista
It seems the Windows Installer installation is broken on that particular machine. You can try reinstalling it and see if the error persists.
