gsimpson
Non-existant drive.
Greetings.
I want to use a drive that may or may not exist that will be populated in the wizard.
Under Install Parameters, I set a Property called DB_PATH that has a default value of Q:\DB.
I then have an editbox that has DB_PATH as the property (with a default value of Q:\DB).
This works very good. Until the drive does not exist, then I get INVALID DRIVE and the installer stops.
I saw this explained and dont know how to implement the fix. I create a Search for the Q drive. Did that. Called in QDRIVE.
What do I do now?
What I would like to have done is to have the editbox filled in with Q:\DB if the Q drive exists, otherwise I would like the editbox showing C:\DB, by default.
The questions I have are:
1. If I create a new custom action, where do I put it? Before something? After something? I dont know what these Somethings are...
2. How do I put the logic of:
IF Q is set
THEN put the value of Q:\QA in the editbox
ELSE put the value of C:\DB in he editbox?
3. What do I put in for the property of the editbox?
Greg
mihai.petcu
Re: Non-existant drive.
Hi Greg,
This should be simple:
- add a search for the location you are uncertain it will exist on the target machine(e.g. RESULT_PROPERTY)
- set the edit box's "Property Name" to RESULT_PROPERTY
- add an init event on the dialog with the edit box:
init event.jpg (34.67 KiB) Viewed 2255 times
You should use WindowsVolume property in the default value of your edit box instead of hard coding it.
