Jimmy
XML Editor: Change in window design
Hi there
I'm not an absolute XML Expert, so I heavily struggled with this.
while edititing a couple of configs in one of our server applications, I noticed, that the overview in XML editor is quite confusing (expecially if the configs are stored partly as elements and partly as attributes.
this leads me to a suggestion, to make the editor window able to show both tabs on one page, divided by a splitter to get dynamical size.
I don't think, it's needed to store the splitter position for each element, I would suggest to hook it only onto the editor window.
Screenshot of the actual view
actual version of xml editor
Screenshot of the suggestion
suggestion, how it could look
Highly appreciate your opinion
Best regards and many thanks for this great tool!!
Jimmy
Re: XML Editor: Change in window design
Hi Jimmy,
Thanks, that is really a very good suggestion. I've created a task for this in our bug tracking system so we can analyze it further more and come up with a better design.
Jimmy
Hello and good morning.
Thank you for your good work!
Are there any news on this?
Best regards and a nice weekend
Jimmy
Hello Jimmy,
Unfortunately this improvement has not been added in Advanced Installer yet. Also, I cannot give you an ETA for now.
Return to “Feature Requests”
