i have a custom action dll (Wix3.0) running only on "Install" and "Maintenance" currently
added in "Files and Folders" under APPDIR.
Is there a way to prevent the dll from beeing installed into APPDIR. The installer
also creates an additional folder "CustomAction.CA.dll-" which prevents the complete remove
of APPDIR on Uninstall, leaving garbage..
kind regards,
alex
