rofo
problem when I add Swedish language in the build.
Hi
When a create msi file I add Swedish language, I chosed a seperate packages.
I add som text/information in Comments that is in Product Support info.
The msi file works, but in Programs and futures, I get wrong information "Comments: PROPERTY.ARPCOMMENTS".
I´m using advanced installer 8.9
Re: problem when I add Swedish language in the build.
If you want that your "ARPCOMMENTS" property to be translated or not you should proceed as follows:
- Go to "Product Details" page and from "Product Details" tab select the "Comments" field.
- From its context menu choose "Localization..." option.
- Now if you don't want that your "ARPCOMMENTS" property to be translated then enable "Never translate this string" option.
- If you want that your "ARPCOMMENTS" property to be translated then enable "Always translate this string -> Using default localization identifier" option.
- After that you must "Create a Translation dictionary" which will set a proper value to the "ARPCOMMENTS" property.
Let us know if this helps, otherwise please give us more details about your scenario.
rofo
It´s works.
