kkkwj
Provide C# code to integrate updater with C# application
Hi, I see that you provide C++ and Java code to integrate the installer with applications. But there is no C# example. Since C# is the new standard language for .NET, it would be useful if you could provide a C# example for how to integrate the updater into a C# program.
gigi
We shall consider to add this is a future version of Advanced Installer. I add this on our TODO list. Thank you for your suggestion.
Gigi
______________
Gheorghe Rada
Advanced Installer Team
kkkwj
Hi, I wonder if you have some C# code around for integrating the updater into an application? It did not make it into the most recent release, so I'm wondering if you could just append some code to this thread to get me going in the meantime... Thanks
gigi
Here is a small sample:
using System.Diagnostics;
//Declare and instantiate a new process component.
System.Diagnostics.Process process;
process = new System.Diagnostics.Process();
System.Diagnostics.Process.Start("updater.exe", "/checknow");
process.Close();
The updater must be located next to the builded EXE file.
Gigi
______________
Gheorghe Rada
kkkwj
Thanks! You make it look so simple compared to the documented c++ version... I'll try this out now that I have an example to follow.
kkkwj
Hi, here is the code that I added to my Main.exe C# assembly, to check for upgrades to my application. The code is based on the code sample you provided in this thread.
The problem is that this code throws up a dialog box ("Your software is up to date OK?") every time it checks for upgrades, forcing me to click OK to get rid of the dialog. I would rather have the program just do the check, and NOT throw up a dialog box if the app is up to date.
Can I do that? If so, how? (The /silent option doesn't seem to do that.)
kj
    // check for updates on the website
    // The updater.exe program must be in the APPDIR sitting next to main.exe
    string path =  "updater.exe";
    if (File.Exists (path)) {
        process = new System.Diagnostics.Process ();
        System.Diagnostics.Process.Start (path, "/checknow /silent");
        process.Close ();
    else {
        MessageBox.Show ("Can't see the updater.exe program");
gigi
To check silently for updates use /silent command line switch for updater. So use this line to call the updater:
System.Diagnostics.Process.Start (path, "/silent");
You can read more about command line switches here:
http://www.advancedinstaller.com/user-g ... dater.html
Gigi
______________
Gheorghe Rada
kkkwj
If you consider my code provided above, I did include the /silent argument. Are you saying that /silent must be used alone? Maybe /silent implies both /checknow and /silent?
gigi
All command line options (like: /checknow, /silent, /silentall, etc) of the updater are made to be used alone. So to check silently for updates use /silent option.
Gigi
______________
Gheorghe Rada
kkkwj
Thanks for the confirmation. Now I'm off to the races!
(You might consider adding this "use these arguments alone" info to the doc, when you add in the C# code to the doc. That's where I went first, before I bothered you in the forum... :-)
AI is a really nice product. And your forum support is really good too.
AI_New_User
Re: Provide C# code to integrate updater with C# application
What does code look like when you want to check for "/justcheck"? The documentation says it returns 0. How would you check that in C#?
To use "/justcheck" in C# you can use the following code:
        private void button2_Click(object sender, EventArgs e)
            Process process = Process.Start(updaterModulePath, "/justcheck");
            process.WaitForExit();
            if (process.ExitCode == 0)
                MessageBox.Show("Update found!");
                process.Close();
In the below screenshot you can see the output, if the "/justcheck" command finds updates and the ExitCode is 0, then the message box is prompted.
This is an example of how to use the return code, feel free to adapt the code to your scenario.
Hope this helps! If you have any other questions, please don't hesitate to contact us.
You are always welcome!
Return to “Feature Requests”
