mcuser
[Solved] Merge modules conflict: Error calling MSI API: 1627
I have an issue when trying to build an MSI. It always worked great, but lately I have updated the 3 msm (merge modules) that are included in the project and I get the following error when building the MSI:
Error calling MSI API: 1627 Method: MsiViewExecute Table: MergeMod
I red some other posts (about 32/64 bits, adding the same msm twice, etc), but none of these threads seems to be covering my use case. The strangest part of this whole thing is that, if I remove one specific synced folder from my project (in Files and Folders), the MSI is built correctly. If I keep that folder and remove the merge modules, the MSI is built correctly.
The AIP file was originaly created with Advanced Installer 8.2. I tried with 9.2, but got the same error.
Anyone has an idea on what could be the problem?
Also, is there a way I can have access to more detailed logs of the MSI build process?
mihai.petcu
Re: Merge modules conflict: Error calling MSI API: 1627
Usually this problem is caused by a duplicate Control Event on one of the installation dialogs. If you cannot find a duplicate control event, please send us the project file to support at advancedinstaller dot com so we can investigate it.
Unfortunately there's no way to show more details other than the ones from the build window.
mcuser
Hi mihai,
Thank you for your answer. I have sent the AIP file by email to support address.
mcuser
Bogdan found the solution to this issue.
Our AIP project has more than 32 000 files when including the MSMs (merge modules) content. The issue was fixed by selecting the "Always consider large number of files" in the "MSI" tab of the "Media" section.
Thank you for all your help!
