kambizt
How to identify the Category for "Control Panel Applets"
I'm using AI Professional version 9.2 and I'm having a hard time figuring out how to change the Control panel applet settings. Here are the two issues I would like to workaround:
1- The shortcut name is very limited for Control Panel applets! is there a way to increase that limit?
2- In newer editions of Windows the Control Panel icons are organized under different categories. the shortcuts created by AI generally go under an unknown category called "Additional Options". Is there a way to configure them in AI so they get listed under other categories like "Hardware and Sound" or "Appearance" ? I found it extermely difficult to find those shortcuts unless Control Panel is set to Classic View.
I appreciate any guidance in this regards.
Thanks.
KT
kambizt
Re: How to identify the Category for "Control Panel Applets"
BTW, I know how to hack the registry and fix it after installation; but I would rather do it throush EXE/MSI installation process.
Thanks.
KT
No, unfortunately this cannot be done. This is a limitation of the API that we are using.
I'm afraid we don't have a predefined functionality to achieve this. Thank you for your suggestion. We have added this on our TODO list and it will be available in a future version of Advanced Installer. However, in order to Assign Control Panel Categories for your applets you should take a look on Registering Control Panel Items article.
I've attached a sample project which implements the scenario.
SAMPLE.aip
(13.12 KiB) Downloaded 641 times
All the bet,
kambizt
Hi Daniel,
Thanks much for your input as well as the sample project you posted.
I have also noticed that when I'm using the "Mixed 32/64-bit matching the platform" option, the Registry changes I have made don't take place in regular branches of registry and instead go under Wow6432Node which doesn't have the same effect. Is there anything I do wrong here? I also built your Sample project and got the same results.
KT
Please keep in mind that on a 64-bit system the registry entries installed by a 32-bit application are created under the "HKEY_LOCAL_MACHINE\Software\Wow6432Node" key. Please take a look on our "Wow6432Node registry key" article. In order to install a registry entry on a 64-bit system under "HKEY_LOCAL_MACHINE\SOFTWARE\" you should mark its component as "64-bit Component" from the "Organization" page. Just press F8 keyboard shortcut from the Registry page while having the registry value selected.
Indeed, my previous sample works only on 32-bit operating systems. Here's attached a sample which works on both, 32-bit and 64-bit, operating systems.
SAMPLE.aip
(18.62 KiB) Downloaded 676 times
kambizt
Thanks a lot for your help.
KT
