AlexanderK
Problem importing NSIS script?
I'm trying to import an NSIS script, but I keep getting the following message:
The NSIS script works fine though? When I try to change the shortcut name, it still gives the same error?
Thanks!
mihai.petcu
Re: Problem importing NSIS script?
Hello Alexander,
It seems you are trying to import the wrong file? .NSH files are actually headers included in the .NSI file but it's the .NSI file you should be importing.
If this is not the case and the import is still failing, please send us all the resources you are importing so we can replicate the issue here and further investigate.
AlexanderK
mihai.petcu wrote:Hello Alexander,
I'm importing the main .nsi file.
I've attached the installation files.
nsis.zip
(33.43 KiB) Downloaded 427 times
Hi Alexander,
We managed to reproduce the problem, it is currently under investigation. A fix will be available ASAP, thank you for bringing it to our attention.
AlexanderK
Bogdan wrote:Hi Alexander,
Great! Any time-frame of when the update will be available?
The fix was included in version 9.3 which is scheduled for release before the end of this month, I don't have an exact release date unfortunately.
