lidds
Progress text...
I have noticed when testing Advanced Installer that if I use the Azure theme as an installer it prompt the user that it is installing prerequities, current file being installed etc.
The thing is that I want this functionality on the Graphite Metal theme. At the moment the Graphite Metal theme only shows a progress bar and no prompt text. Is there a way that I can add this functionality to the Graphite Metal theme.
Please keep in mind that I am new to Advanced Installer and therefore if possible would need step-by-step instruction.
Thanks in advance
Simon
mihai.petcu
Re: Progress text...
Hi Simon,
Yes, you ca easily do this from the Dialog editor.
Just recreate or copy-paste the following control from one theme to the other:
lidds
Thank Mihai,
This worked perfectly.
