AINewUser
Maintenance Type Selection Dlg
Advanced Installer Version : 8.9
We want only "Remove" action on Maintenance Type Selection Dlg. So we removed "Modify" and "Repair" radio buttons and kept "Remove" as selected.
It works fine with exe setup.
If we run .msi then it gives error. I am uploading image showing error as attachment.
Please help us to solve this problem.
Thanks & Regards,
Error
Error
mihai.petcu
Re: Maintenance Type Selection Dlg
Can you please send us the project file (.AIP) to support at advancedinstaller dot com so we can see your settings?
AINewUser
Hi Mihai,
I sent project file at support at advancedinstaller dot com.
The error that you see is given by Windows Installer, it appears because by design the OS does not allow having a radio button group UI control with only one button,
this would be pointless, as the user would be forced to select the same button, therefore it would not be a choice but a hard-coded option. For this is recommended you delete all the radio buttons and the group and just set the property "MaintenanceTypeOption" to the string "Remove" using a "SetProperty" Init Event.
This is the property which is set by the radio button group, setting automatically is identical with the user selecting "Remove".
Another option, which I don't recommend, is to have Enhanced UI set to "Always" from Themes page. This will make the EXE setup to always control the MSI dialogs, which it ignores this type of errors.
AINewUser
Thank you very much for your help.
Always a pleasure.
