In our product we are setting two system environment variables. However,immediately after installation the new variables are not visible from command line (ie. not available as user variable).
We noticed it takes some time to propagate system variables available from command line, or, when we press 'Ok' from Control Panel\System and Security\System - > Advanced System settings -> Environment variables it gets propagated.
Windows version used is Win7 64 bit.
Do you know, what we need to perform in order to make the system variables available to local user immediately?
Can you help?
regards,
Mahua
