Marek
Service is not starting after install
There is a little problem in specific situation.
I have a service created by Visual Studio 2008 as ATL model service.
After install the service does not starting.
I investigate this problem and discovered that there is absence of the required registry entries.
ATL service model create RGS script which contains the entries.
In my case it looks like this:
HKCR
	NoRemove AppID
		'%APPID%' = s 'M3SAlarmRecv'
		'M3SAlarmRecv.EXE'
			val AppID = s '%APPID%'
If I use command "M3SAlarmRecv.exe /Service" to register my service everything is OK.
Executing this command performs RGS script that creates the registry entries.
Can you do something to the AI works correctly with ATL service model?
I suggested that the AI looked into the resources of EXE file, found the RGS script, parse him and create registry entries in AIP file.
This is REG file which corresponds to the RGS script.
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\AppID\M3SAlarmRecv.EXE]
"AppID"="{7559AC8D-BE8B-437B-9216-140626A607AC}"
[HKEY_CLASSES_ROOT\AppID\{7559AC8D-BE8B-437B-9216-140626A607AC}]
@="M3SAlarmRecv"
"LocalService"="M3SAlarmRecv"
Best regards
Marek
mihai.petcu
Re: Service is not starting after install
Hi Marek,
I have forwarded your request to our development team so they can review and consider it for a future version. In the meantime, as this is a particular case and has no native support in Windows Installer, it can be implemented with custom behavior.
