I have an application that requires a couple prerequisites and a couple drivers to function. I developed the installer on Win XP where it seems to work but when I go to a Win 7 machine the installer fails because the drivers cannot be located. Any clues as to how to go about debugging this? Using Enterprise Edition. Thank you.
Are you using the Drivers page to add the drivers? If so, you can try to manually install those drivers on Windows 7 outside the installer and see if the behavior persists.
