bhawkins
Unistall as Part of Patch - Source Unavailable
I am running into a problem where the Patch is not able to continue due to the fact that the unistall does not have access to the source install routine to perform the uninstall.
The Update is detected - good.
Patch is downloaded - good
Patch is ran - good
Uninstall - NOT able without this source - bad
Screen Shot
Uninstall Issue with Patch.jpg (63.02 KiB) Viewed 5764 times
This is with Admin like user ... that is able to uninstall directly.
Since they are able to Uninstall using the uninstall that is provided with the Advanced Installer install (shortcut) ... I am not sure why the Patch Update is giving me this message.
Help !!!!
Cheers,
Bruce
Note: If I actually put the install CD in and direct the displayed prompt to that original CD install, the following is displayed:
"An Installation package for the product ResourceMate could not be found. Please install again u..."
<ok>
The actual message is truncated exactly as displayed.
Re: Unistall as Part of Patch - Source Unavailable
This may happening because the patch cannot find the original MSI. A solution would be to build the original installation package as an EXE package and use the "Do not delete extracted MSI and CAB files" option from "Media" -> "Configuration" -> "Bootstrapper Options" group. This way the extracted package will remain on the target machine after install.
Let us know if this helped.
bhawkins
Hello Daniel,
Thanks for the reply. So any idea why it can not find the original MSI?
I am using the Package Type: "Exe setup with resources next to it" I have assumed that since there is no option about deleting the msi - that this would be available by the system.
I will test the option for Package Type "single exe setup (resources inside)", however, not really happy that I have to do this without a clear understanding why.
[Edit] So I created an older original install 4.0.7 lets say and then applied the patch for 4.0.8 and did not get the problem and everything worked.
Cheers,
Bruce
Hello Bruce,
Please keep in mind that when Windows Installer installs a MSI file it caches it in the hidden "Windows Installer Cache" directory . Also, the cached MSI is stripped of any files it may contains for saving a significant amount of space required by larger packages. This is part of the reason for prompting for source when the original media files aren't available.
When patching, if the required MSI and media files are not available Windows Installer will search for it in the location the MSI was originally installed from. If they aren't located then will prompt for it.
