frjames
Predefined Prerequisites
One of my prereqs is Visual C++ 2008 SP1 Redistributable. On a clean server 2008 environment, this will initiate its install and it runs successfully. When I uninstall my program as well as C++ from programs & features, when I run my installer, the prereq doesn't fire. Attached are my options. How can I get it to install C++ every time if it's not installed?
James
Re: Predefined Prerequisites
Hello James,
I've tested your scenario, but I cannot reproduce the behavior. Can you reproduce this behavior on multiple clean machines? If so, can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
frjames
Your support team suggested I include everything into an exe as I'm using the enhanced installer - and I can't get that to run w/ your msiexec /i "C:\MyPackage\Example.msi" /L*V "C:\log\example.log" command example. Does it have to be an msi?
Hello James,
Please keep in mind that when your package installation is included in an EXE bootstrapper the command line no longer uses "msiexec". So, if you want to create a verbose log of the installation for an EXE file created with our bootstrapper, then the command line should have this form:
<path_to_exe> /L*V <path_to_log>
For example, the command line can look like this:
"C:\MyPackage\Setup.exe" /L*V "C:\log\example.log"
Let us know if this helps, otherwise give us more details about your scenario.
