aschuurhof
Create a new installation from existing aip
How do I create a new installation from an existing aip, so I can install them concurrently?
Re: Create a new installation from existing aip
In order to achieve this you can create a project template, using "Save As Template..." menu item, starting from the current project file (aip) which will be reused to build a different package.
aschuurhof
Tried that and got the following error at saving the template:
[SEH_AV_READ_BADPTR] ACCESS_VIOLATION (0xc0000005) at address [0x0044d5b0]
*** Stack Trace (x86) ***
[0x0044d5b0] -----
[0x0123b59f] -----
[0x0125c790] -----
[0x773796c5] SendMessageW()
[0x00404099] -----
[0x00b1a37e] -----
[0x0042112f] -----
[0x721f070b] DSA_Sort()
[0x72201618] InitCommonControls()
[0x773762fa] gapfnScSendMessage()
[0x77376d3a] GetThreadDesktop()
[0x77380d27] GetClientRect()
[0x77380d4d] CallWindowProcW()
[0x00435dd9] -----
I'm not sure why you are encountering this behavior. Can you please send us the problematic .aip (project file) to support at advancedinstaller dot com so we can investigate it?
