Thomas Möller
How to deselect a language?
I try to setup an installer in German language. I have the problem that I can not remove "English" from the list. There is no message. I just can not deselect the checkbox.
What do I do wrong?
TIA
Thomas
Thomas Möller
Re: How to deselect a language?
I have installed v 9.2
I did some additional investigations. I added a new project. Then I switched directly to "Translations". There I added "German (Germany)". I can not deselect "English (United States)".
I can add any other language from the list - and I can deselect it. But I can't deselect "English (United Sates)".
TIA
mihai.petcu
Hello Thomas,
The project language cannot be excluded from the Translation page. The default project language is English but you can change it when creating your project from Start Page -> New -> Options dropdown menu.
Thomas Möller
Hello Mihai,
thank you for your information. That did the trick. My problem is solved.
Regards
Thomas
litu
Is there any way to change the project language than starting the whole project from the scratch?
I'm afraid there is no way. You should recreate your project if you want to change its default language.
In your current project, what you could do is to only add another language, from "Translations" page, and build a multilingual project.
