wyzerd
XML Import error
New in version 9.4, I am unable to import xml. see attached error dialog.
MonacoSetup.aip
(260.19 KiB) Downloaded 397 times
3D.xml
(961 Bytes) Downloaded 521 times
Re: XML Import error
We have tested and reproduced this issue and it is currently under investigation. Thank you for bringing it to our attention. Please give us some time to investigate and we'll get back to you as soon as we have a conclusive answer.
It seems the related issue is generated by your project current state and not by the xml import operation. Can you please tell us how it is created your project? For example did you use our import features (Repackager, MSI import, etc.) in order to add resource files to your project or you manually add the resource file from "Files and Folders" view? Also, did you manually edit the .aip file?
wyzerd
It was created manually sometime ago. I think I recreated it in 8.5 but I can't recall for sure.
There was a manual edit to the aip last year to get around the edit bug on the "Extract Location" not being able to be saved.
Can you please attach the latest working version of the aip file, before it was upgraded to Advanced Installer 9.4? The degree of corruption of the current project is quite large and a manual fix from our part could fail.
