squagel
Custom 32bit/64bit mixed behavior
I have AI Pro and a mixed 32/64 project which works well. On a 64-bit machine, Is there any way to allow the user to install the 32-bit feature INSTEAD of the 64-bit feature via the "Customize" page?
Thanks!
Re: Custom 32bit/64bit mixed behavior
Can you please tell us why do you want to achieve this? If you need to install only the 32-bit resources of your installation package on a 64-bit machine, then you can create the installation package as a 32-bit package type.
squagel
Well, I want the default behavior to work as it does now, i.e. 64-bit binaries installed on x64 machines and 32-bit on x86. However, in some cases, we'd like to be able to install the 32-bit binaries on x64 machines. If the only option is a second 32-bit-only installer, then that's fine. I was just hoping that there would be a way to make it conditional to avoid having to make a second installer.
In order to achieve this you can enable “Install these files on 64-bit platforms” option when adding 32-bit installation files using "Mixed 32/64 Package Organization Wizard".
Let us know if this helped.
