dicestacking
Compilation Error/Build Error
In our company we produce Software, and sell them in packages.
Soon we release a package with 5 different programms.
I created an Enterprise Project of your Trial Version, then imported 5 .msi-files, and split them in 5 different folders for each .msi, compiled and got this error:
Checking builds status... done.
Build required.
[ DefaultBuild ]
Building package (en): C:\Users\Markus\Desktop\AdvancedInstaller\pmOneSuiteSetup-SetupFiles\pmOneSuiteSetup.msi
Reusing archives from cache... done.
Creating MSI database... error.
Error calling MSI API: 1627 Method: MsiDatabaseImport Table: _VsdLaunchCondition. Extended Error: 1: 2216 2: C:\Users\Markus\Desktop\AdvancedInstaller\pmOneSuiteSetup-SetupFiles\pmOneSuiteSetup.msi 3: _VsdLaunchCondition.idt 4: 5 .
All what u have to know is if it will work soon we will buy the Enterprice License :D
greetings from austria
markus
dicestacking
Re: Compilation Error/Build Error
UPDATE:
Okay i found the mistake, but still, i rly don't know what it is.
The only thing i know is if i delete the "Table Editor" entry "_VsdLauncherCondition", i can build the project.
But i don't want to risk something and want to ask you, what this is. I upload the screenshot for you.
markus
Hello Markus,
Please keep in mind that the import features in Advanced Installer (the Repackager, the Import MSI feature etc.) are intended to be used to get a starting point for your installation package, not to completely reproduce other installation packages. The Repackager tool captures only the effects of the installation (the changes made on the system). If the original installation package executes custom code (programs, scripts etc.) then only the effect will be captured (registry entries, files and folders etc.). Also, after repackaging an installation some adjustments may be necessary in order to obtain a working installation package.
You can try to delete the related table (_VsdLaunchCondition) from "Table Editor" page, then build and run your installation package and see if the installation is successfull.
