den
Minor localization issues
I've recently began to create multilanguage builds of our headliner product with enterprise Advanced Installer 9.4.
I've encounter some minor localization issues:
1. Russian language in selector starts with lower case letter (see attachment russian_lang.PNG).
2. In Bootstrapper UI section I use "Display Information dialog" and "Override information text with .rtf file". But I can't set different .rtf files for different languages.
3. When setup ends it displays "Deleting extracted files..." message for short amount of time regardless of the language, but I've failed to find this string in dictionaries. Is it hardcoded into bootstrapper?
Daniel.
Russian language in selector starts with lower case letter.
mihai.petcu
Re: Minor localization issues
Hi Daniel,
This seems to be related to that particular machine because Advanced Installer uses an .API which returns the string.
Here's How do I localize the EULA and ReadMe text? article to help you with this.
Is that text the following:
<STRING id="ActionText.Description.AI_DeleteLzma" value="Deleting files extracted from archive"/>
I found it in the custom English dictionary.
den
Hi, Mihai,
Can you tell me more about API you use to extract language name string, so I can test it independently?
Thank you for link to the 'How do I localize the EULA and ReadMe text?' article, that will be helpful.
About 'ActionText.Description.AI_DeleteLzma' string - at first I thought so too, but actual text you can see in attachment 'installer_end.png'.
Sorry for low quality screenshot, it was hard to get.
Daniel.
Actual text appearing at the end of the installation.
den
Is there any news about this issue?
Daniel.
Cosmin
Hi Daniel,
This is actually a bug in Advanced Installer and it will be fixed in a future version. Thank you for bringing it to our attention.
The text in your screen-shot is displayed by the EXE bootstrapper. Unfortunately we don't have a translation for it for Russian. If you can provide one, we will include it in the next release.
Cosmin
den
Hello, Cosmin,
Thanks for your explanation.
We are now translating installer of our headliner product to 9 languages (German, Spanish, French, Italian, Dutch, Portuguese, Russian, Swedish and simplified Chinese), so I can provide you translations of 'Deleting extracted files...' for all 9 languages if you like.
And I found another issue regarding package localization.
In my project I always use Enhanced User Interface (option 'Use Enhanced User Interface: Always (install, uninstall and maintenance)' in Themes).
When package was installed using some language other than english (which is default), on uninstall interface is displayed in english.
Daniel.
mihai.petcu
Hi Daniel,
This can happen for several reasons. Can you please send us the project file (.AIP) to support at advancedinstaller dot com so we can see you current settings?
den
Hi, Mihai,
I've sent you my .aip file to support email. Thanks in advance.
Daniel.
mihai.petcu
We have tested this using the same settings as in your package and everything worked as expected. Installing in Russian for example will trigger the uninstall in the same language.
Can you please generate a bootstrapper log for install and uninstall so we can see what's happening on your machine?
den
Hello, Mihai,
Ok, I'll try to investigate this issue further.
Daniel.
den
Hi, Mihai,
I've create install log using .bat-file with command like this:
"[Path to executable]" /exelog
How can I get uninstall log, when I launch uninstall from "Programs And Features" console (OS is Windows 7)?
I guess that problem occurs because MSI databases for different languages have different product codes and on uninstall there is only one database for english language available. Maybe I should use "Do not delete extracted MSI and CAB files" bootstrapper option or something similar?
Daniel.
mihai.petcu
Hello Daniel,
Unfortunately you can only generate a log by using the command line. Just use the /exelog command line when running the package in maintenance mode.
Our testing with the default settings did not out the same behavior so there could be a problem with that particular machine. You can try the package on other machines and send us the logs so we can further investigate.
den
Hello, Mihai,
If I run the package, which was installed in non-default language like Russian, in maintenance mode, everything works fine and UI is translated into Russian.
My actual problem is: when I launch uninstall from "Programs And Features" console, UI is displayed in default English language regardless of language used at installation.
I don't think this issue is someway related to particular machine because it can be easily reproduced on any machine (physical or virtual) which I have at my disposal.
Daniel.
Hello Daniel,
In order to achieve this you can see my response from "Enhanced UI in uninstall problem" thread.
den
Hello, Daniel,
I've answered you in the corresponding topic.
Daniel.
