First of all I apologize for this inconvenient. Please keep in mind that our "Update TXT files" feature is available only in an Enterprise or higher project type.
However, in order to achieve what you want you can proceed like this (using a Professional project type):
- Go to "Files and Folders" page and add the related .EXE installers (i.e.
one.exe,
two.exe and
three.exe) in the "Application Folder".
- Create a .BAT file (i.e.
My_Batch.bat) with the following content and add it in the "Files and Folders" page:
- Go to "Custom Actions" page and add a "Launch file or open URL" custom action with sequence after "Install Execution Stage" -> "Finish Execution" action group like this:
- Command: "[#My_Batch.bat]" "[APPDIR]"
- In the "Execution Properties" group on the right page make sure you choose the "Asynchronous execution, do not wait for return" option. Also enable only the "Install" option from the "Execute Sequence Condition" group.
-Build and run your project.
Let us know if this helped.
