murug86
Property Set with Formatted
First, I added a 'New Property' in "Instal Parameters" Page
Second, I added a 'Property Based Folder' in "Files & Folders" Page
Third, I added a 'Path Edit' control with this property as 'Property Name' in "Dialogs" Page
Finally, I have a 'Property Set with Formatted' custom action which presets a value to the property, in "Custom Actions" Page
I need this preset value, to be the path of a folder in the Application Folder; as seen below : I'v selected the webapps folder.
Property Set with Formatted.png (54.84 KiB) Viewed 7114 times
BUT, during installation, the value in the 'path edit' is the name of that PROPERTY, as seen below:
mihai.petcu
Re: Property Set with Formatted
This is happening because that folder (webapps_Dir) is resolved during a later standard action (CostFinalize).
Also, a property used by a property-based folder must contain a valid path. If this is not the case and the path cannot be resolved, the installation will fail. Keeping this in mind you should move Initialize_SMARTE_SERVER_HOME after CostFinalize standard action and add another similar custom action after Begin that sets SMARTE_SERVER_HOME to [WindowsVolume] for example (this path should exist on any machine).
murug86
Hi Mihai..
mihai.petcu wrote:Also, a property used by a property-based folder must contain a valid path.
Yes, I know. I'm obtaining this from the 'Path Edit' control [ Server Home : ]
mihai.petcu wrote:add another similar custom action after Begin that sets SMARTE_SERVER_HOME to [WindowsVolume]
I am able to do this too. By default it shows C:\
BUT, I was hoping to be able to show a different value by default (instead of showing { c:\ }).
Just let me know IF this is possible.. :)
mihai.petcu
Yes it is. Have you tried configuring the custom actions like I mentioned in my previous post?
-> add a "Property set with Formatted" custom action after Begin that sets SMARTE_SERVER_HOME to [WindowsVolume]
-> move Initialize_SMARTE_SERVER_HOME custom action after CostFinalize
murug86
Sorry Mihai..
I understood it only when you stated it as two separate points. :)
I did it. It worked. Awesome.. :)
For other visitors :
First enabled the "Cost finalise" inside the 'InstallUIsequence' stage.
Then moved the Initialize_SMARTE_SERVER_HOME under it.
mihai.petcu
No problem, glad you solved the issue.
