Paul Dean
Suspicious.cloud.5
One of my clients is using SYMANTEC ENDPOINT PROTECTION 2012 version 12.1.1101.401 and when trying to install an application that I had assembled with Advanced Installer versaion 9.4 as an .exe file they recieved a warning "Suspicious.cloud.5". The file was quarrantined and they were not able to continue with the installation of my application. I see from a previous posting in 2011 that a similar situation was reported and that you were looking into this problem with Norton.
Any suggestions or advice on how to get around this problem?
Paul
mihai.petcu
Re: Suspicious.cloud.5
Hi Paul and welcome to Advanced Installer forums,
Back then the issue was caused by "vmdetect.exe" file used for the launch condition which detects if the setup package is running inside of a virtual machine. Although this file was whitelisted by Symantec, are you using this launch condition in your package?
Also, can you please scan the folder containing your application's files included in the package? This may not be installer related.
