jennnn
Launch Condition on Search(Registry key exists) fatal error
My ultimate goal is: I would like to have the installation quit if a specific registry key doesn't exist.
I have attempted to setup a Custom Behavior --> Search with a criteria of "Registry key exists". This seems to be working correctly without any errors.
Then I added a Launch Conditions --> Custom condition that refers to the Search.
When I run the installation, if the registry key does not exist, then I get an error page that reads, "...setup ended prematurely because of an error. Your system has not been modified. To install this program at a later time, please run the installation again."
Is this the correct behavior? The "ended prematurely" wording wasn't what I was expecting. I tried to look and see if I could modify this dialog text and I didn't see this particular "fatal error" dialog box available...? In the log, it says that a fatal error has occurred:
MSI (c) (CC:FC) [08:40:12:217]: Doing action: LaunchConditions
Action 8:40:12: LaunchConditions. Evaluating launch conditions
Action start 8:40:12: LaunchConditions.
Launch Condition Description
MSI (c) (CC:FC) [08:40:16:510]: Product: AcuPort Advanced 7.00 -- Launch Condition Description
Action ended 8:40:16: LaunchConditions. Return value 3.
MSI (c) (CC:FC) [08:40:16:560]: Doing action: FatalError
Action 8:40:16: FatalError.
Action start 8:40:16: FatalError.
MSI (c) (CC:3C) [08:40:16:626]: Note: 1: 2205 2: 3: AI_ControlEx
MSI (c) (CC:3C) [08:40:16:651]: Note: 1: 2228 2: 3: AI_ControlEx 4: SELECT `Dialog_`,`Control`,`Type`,`Parent`,`Attributes`,`Data` FROM `AI_ControlEx` WHERE `Dialog_` = 'FatalError'
Action ended 8:44:10: FatalError. Return value 1.
MSI (c) (CC:FC) [08:44:10:737]: Doing action: AI_SHOW_LOG
Action 8:44:10: AI_SHOW_LOG.
Action start 8:44:10: AI_SHOW_LOG.
MSI (c) (CC:B8) [08:44:10:807]: Invoking remote custom action. DLL: C:\Users\test\AppData\Local\Temp\MSI3C04.tmp, Entrypoint: LaunchLogFile
Action ended 8:44:10: AI_SHOW_LOG. Return value 1.
MSI (c) (CC:FC) [08:44:11:004]: Doing action: FatalError
Action 8:44:11: FatalError.
Is this the correct behavior or have I set something up wrong?
Re: Launch Condition on Search(Registry key exists) fatal er
I'm not sure why you are encountering this behavior. Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
jennnn
Thanks for your reply...I've sent both of those files.
Any information is appreciated,
Jenny
Hello Jenny,
I'm afraid I misunderstood your scenario. Please keep in mind that this is the default behavior when a launch condition isn't fulfilled.
If you want to edit the "Fatal Error" dialog you need to use our "Dialog Editor" feature which is available only in an "Enterprise" or higher project type.
jennnn
Thanks...that was my question--glad to hear it is working.
