KorksKill
Disable PrepareDlg
is possible disable the "PrepareDlg"?
I created the Splash Screen in another program, but when it starts, PrepareDlg is behind it, is possible disable it? or make a splash screen before starting?
Note: The Splash Screen is in exe format
Re: Disable PrepareDlg
You cannot disable "PrepareDlg" when running with full UI. What you can try is to schedule your custom action, i.e the splash screen, as "Synchrounous execution, wait for return code" and the first one in th e sequence of actions from Custom Actions page. This way the installer should wait for your EXE to close before continuing.
KorksKill
the program has no "Synchrounous execution, wait for return code" it has "Asynchronous execution, wait for return code at the end of sequence"
But now I'm confused.
I would like you to explain to me again, and more detail if possible.
Thanks.
mihai.petcu
The difference between "Synchronous execution, wait for return code" and "Asynchronous execution, wait for return code at the end of sequence" is described in the following article:
Custom Action Properties
You have a couple of solutions regarding this you can try with full UI:
1.
- add your splash screen custom action and set it with "Synchronous execution, wait for return code"
- condition PrepareDlg from the Custom Actions page so it can be skipped
2.
- add your splash screen custom action and set it with "Asynchronous execution, wait for return code at the end of sequence"
- add another custom action that stops the splash screen before WelcomeDlg standard action set with "Synchronous execution, wait for return code"
The second custom action avoids showing the splash screen during WelcomeDlg.
Athcb
From Table Editor in the left panel, in the table dialog deletes the dialog that you want to disable.
Sorry for my bad English.
Redgas.
Guillermo
mihai.petcu
Hi Guillermo and welcome to Advanced Installer forums,
I don't understand what you mean, if this is a bug report, please give me a step by step test case leading to the behavior.
To delete a dialog you can do so from the Dialogs page. However, PrepareDlg cannot be deleted, it is a mandatory dialog.
