DimasSup
Localization problem
Hello!
As you can see on screenshot - not all text are translated on default welcome dialog(and some others) for Chines UI. same problem on Spainish UI. and Thai UI. in Russian UI all alright.
I checked advanced installer ui dictionary - all strings had normal translated
Current version of Ai- 9.5.
I check build builded with 9.4 - same problem
Re: Localization problem
This seems to be an Advanced Installer issue, thank you for bringing it to our attention. A fix will be available in a future version of Advanced Installer. Until then, as a workaround you can proceed like this:
- Go to
C:\Program Files (x86)\Caphyon\Advanced Installer 9.5\themes\spring\fragments
and open the "UI.aip" file with a text editor (i.e. Notepad++).
- Search for your untranslated string id (i.e. Control.Text.WelcomeDlg#Title) the corresponding ValueLocId (i.e. Azure.Control.Text.WelcomeDlg#Title).
- Rename the related ValueLocId to your string id (Control.Text.WelcomeDlg#Title) and save the "UI.aip" file. Please keep in mind that on Windows Vista or above you should move the related file on a location where you have write permissions (i.e. on your Desktop) in order to edit it and then copy the "UI.aip" file back in the initial location.
- Restart Advanced Installer and rebuild your project.
