jack128
Non ASCII characters in New/Edit File Removal dialog
Hi.
If I have non ASCII characters in file name(cyrillic in my case), then there are invalid chars in Edit File Removal dialog. Bug?
OS Win7 x64/Rus, Advansed Installer 9.5/Trial
mihai.petcu
Re: Non ASCII characters in New/Edit File Removal dialog
In order to use language specific characters in an installation package, the codepage used during the installation of that package must be of that specific language.
For example Japanese characters. This will work if Japanese is one of the languages in the package (not necessarily the project language) and the installation is performed in Japanese (the user has the system locale set to Japanese).
jack128
I set UTF-8 in Deployment/Media/Builds/Comfiguration/Database Code Path, but error dont'n disappear. Setting "build language specific codepage" give same result.
Note, there is not bug in "Edit shotcut properties" dialog. May be it's GUI bug?
What If user has en-us locale ???
mihai.petcu
You don't have to change any of those settings. The default "Build language specific codepage" option is fine.
Just include the language for that Cyrillic file name from the Translation page and then perform the installation in that language.
I don't understand what you mean by this. Can you please give us more details (maybe exemplify)?
If the system you're installing on does not have the locale set to a Cyrillic language, it will not ensure Cyrillic characters will be displayed correctly every time.
