bullyellis
Setting focus on a custom action
I have a custom action which runs a .exe file. The .exe file is an IBM Informix ODBC setup. My issue is sometimes when this .exe is run, it gets put behind the installer windows, so the user does not know to finish that setup before proceeding. It does not seem to happen all the time. I have attached a screenshot of my current settings for it.
focus error.png (70.62 KiB) Viewed 3427 times
mihai.petcu
Re: Setting focus on a custom action
Here's "Custom Action Launches in background behind installer" thread to help you with this.
bullyellis
Mihai,
Unfortunately, as you can see in the screenshot, the "Commit with no impersonation" option is greyed out and unselectable.
Any other ideas ?
mihai.petcu
Indeed those options are not available after InstallFinalize standard action. Since you're trying to run a second setup, you can try adding it as post-install prerequisite.
