ChristianLA
32bit & 64bit Drivers for a 32bit app in a mixed project
Hi:
I' have read the related topic for this issue and setup my project as Mixed 32/64bit, since the application is a 32bit one, I also have two kind of drivers (for the same device) of 32 and 64 bit (inf, cat & sys). I have ADVINST v9.1.1
To install the drivers I have done this:
- Load the inf file of the 64bit and proceed normally, using only this 64bit driver the installation halts with the DIFXAPP error that states I'm not running a 64 bit dll when attemping to test the installer in a Win7 64bit machine
- Load the inf file for bot 32 & 64 bits, first the inf files had the same name but only one item was created on the drivers list, therefore I rename one of them and then it showed me 2 items, but installing on a 64bit the installation halts with the DIFXAPP error that states I'm not running a 64 bit dll
-In any case even if I select options in the checkboxes they appear unchecked in the drivers item
Is there any way to validate what driver is the one to install because I read this is decided automatically.
Thanks in advance
mihai.petcu
Re: 32bit & 64bit Drivers for a 32bit app in a mixed project
Hello Christian,
First off you should have an .INF file for each driver (32-bit and 64-bit). This is mandatory.
The steps to add drivers in a mixed package are very simple:
- First choose Mixed 32/64 project type from the Install Parameters page and follow the wizard
- Add your drivers' resources from the Files and Folders page
- Then go to Drivers page and add each driver's .INF file. After completing this step, everything should be automatically assigned and working.
We recommend you first try manually installing the drivers outside the installer to make sure they work as expected.
